Door Lamp Led
lysyadam27
EGR delete
Hello, my door light in the side panel does not work. Does anyone have a way to do this because it doesn't seem to be available at an authorized service center?IMG_7436.jpeg
I assume you mean a light in the pocket etc? You will need to take the door off I guess to check a) whether its a broken bulb/led or b) a wire disconnect or maybe a fuse, however if only one door I doubt it will be a fuse.
