Mistuk Air-Traffic Controller VIP Member T6 Pro 22 Feb 2020 #1 Ok so I’m a bit on the heavy side, but the driver seat hacks me off in my T6 as I need to constantly ratchet the height up (every time I drive it) anyone know of an adjustment to tighten it up to stop it lowering? thanks
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 22 Feb 2020 #2 It's more when you get in/out of the van you inadvertently move the ratchet...... dropping down a tiny bit...each time. Someone suggested before to just remove the ratch handle, once you had it set to the top.....or wherever.
Mistuk Air-Traffic Controller VIP Member T6 Pro 22 Feb 2020 #3 Mine can move during a long journey. As I say, I’m a bit heavy (19st) but it’s not happened on any other vehicle
G Griffiths1593 New Member 3 Dec 2020 #4 Mistuk said: Mine can move during a long journey. As I say, I’m a bit heavy (19st) but it’s not happened on any other vehicle Click to expand... I keep having the same problem with mine, have you found a solution? I'm around 12 stone and it still does it
Dellmassive T32 204 DSG LWB SLN PV MY18 & T30 SWB KMB MY67 VCDS User Moderator VIP Member T6 Master 3 Dec 2020 #6 Try this...... take handle off for a month to test... 'It's more when you get in/out of the van you inadvertently move the ratchet...... dropping down a tiny bit...each time. Someone suggested before to just remove the ratch handle, once you had it set to the top.....or wherever."
