Denver41671
Hi everyone! So, yesterday the comfort feature on the drivers side stopped working, I had to hold my finger on the switch to get it down or up. Not a hardship but if something's not quite right, it annoys me Quick search on here and found it can lose it's setting and needs to be reset, which I did and it worked. Giving it a few test runs and it stopped half way and dropped open again, I think that was caused by the clips for my wind deflectors, it was dropping around the point of the first clip, so removed and relocated, few test runs and all ok. Then something weird happened, I opened the window, went to close it and nothing happened, the switch was dead. Passenger side fine. Left it a couple of minutes and tried again, and it worked fine. It did this a few times. Wasn't ideal as the window was stuck open at 9pm Anyway, it's closed now, but just curious (and worried about opening it again)... Is it a fault with the switch, the motor, or is there a safety feature that disabled the window for a period of time?
