Found Drivers side Kombi sliding window
Higgidav
I’m looking for a drivers side Kombi sliding window for a 2018 T6. I only want the openable unit but would take the whole window if anyone has one available.
My window has failed behind the seal and VW will not provide a warranty replacement under the All In Plan as glass and seals are excluded although it is the window frame that has failed.
Surely you can claim warranty on corrosion aside from it being a window issue?
I thought it would not be a problem but VW have said no and also told me that I cannot appeal.
Hi, many thanks for your kind offer. I have replaced the sliding unit with fixed glass.
Hi @Higgidav ,
How much did that cost if you don't mind me asking. Am going to do the same. My leak is so bad it's rotted out the door card.
I went with OEM glass. It was around £400 supplied and fitted including removal of the leaking unit. The OEM glass is around £220 alone.
