Driverside sidelights problem on crash repaired t6 ?
dubtastick
My t6 2019 swb driverside front and rear sidelights are not working ,
I replaced the front sidelight bulb with an led witch caused them too work for a short while although the rear bulb did get hot then failed since then a warning bulb has lit on the dash I have replaced the front bulb with a standard one but it isn't working ?,
I have replaced the driverside side indicator with a seqential one as it was damaged in a crash ,could this affect things ?
Many unknowns here, depending on the severity of damage there could be issues.
Unless you are able to diagnose electrical fault your best bet is to visit a trusted auto electrician.
Hi, I have the same issue, did anyone know which LED bulb will resolve this issue?
