Dynamic indicators LED issue
asedas
Hi all,
I'm struggling with strange random issue. I've put dynamic led turn signal indicators on my van, but they started blinking fast (hyperflash) from the time to time. It's totally random, it starts, then after while works normally, then hyperflash again, goes back, etc. No errors in logs (long time ago I had bulb warning but disappeared "immediately"). I thought it's light itself but took it off and checked offline and looks like working... what that could be? relay?
Second thing is that I've noticed that there are some turn signals relays designed for led... should I have such?
Thanks for advice
:whistle:
As I have mentioned before(somewhere else;)) some sequential LED strips are voltage sensitive.
For example they work perfectly with 12V DC and then they misbehave with increased voltage of 14.5V DC(when engine is running).
Luckily these strips are very rare and majority of recent/modern strips cope very well with increased voltage.
Then there is another trap :whistle:.
Indicator's pulses can be PWMed(Pulse Width Modulated) and this is controlled by the BCM coding.
Almost all aftermarket LED strips don't like PWM and they won't work properly, especially when engine is running.
This is how indicator pulses look like when PWM is ON and engine is running.
And this is how indicator pulses look like when PWM is OFF and engine is running.
To deactivate indicator PWM the following VCDS coding modification needs to be applied.
09 BCM, (Byte 19, bit 3) = 0 (unticked)
