Eberspacher Factory Air Heater Reprogramming.
sp00k
Is there a way to change the T6 California's Eberspacher to run on set power level instead of a current temperature level? (It is a Beach version control unit if that helps, probably same in Multivans.)
After years of using the heater in cold weather getting seriously annoyed at the way it is controlled.
When setting on level2 it tries to keep the temperature at a specific level, resulting in lots of shutdowns and firing up again. All I need is to tell the heater to always run on the lowest possible power setting and I will be insanely happy.
