Apparently the yellow wire is a switched negative to make the heater run but it m not sure if that will work with our setup, temperatures etc.
I’m gunna fit a Renogy core control panel that has the ability to control relays remotely through an app, it would be nice to be able to turn the heating on with it.
I’m sure someone on here will have connected a secondary switch to an eberspacher??
