JoelSinj
Morning peeps,
I was wondering if anyone has has a go with Cleaning with DFP fluid without the agony of dismantling all the components in their T6? Even removing the EGR pipe to inspect deposits in my 2017 T6 is a pig.
The video on the hyperlink seems nice and straightforward and the comments are near enough all positive in its results. I’m considering doing it to mine. Take of the intake manifold, remove MAF sensor, spray into intake at maintained 2000rpm (use a brick or brolly), deploy 1-2 litres, watch billows of smoke, drive for 10 miles with some well…hey presto…apparently.
From watching many others doing this, it cleans:
- intake manifold
- Anti shudder valve
- intercooler
- inner casings
- EGR valve and pipe
- Turbo
Some people use DPF cleaner like Wynns using a spray bottle of high pressure pump action fence sprayers. Pic attached.
Or your can use Liquid Moly premade diesal cleaner in the pic attached.
It’s all seems like a no brainer if EGR restricted flow is popping up. Especially as I’ve also read changing turbo, EGR and other items hasn’t fixed their EML, but this simple carbon flush has….after their work was done. So they maybe should have tried this first. That’s where I’m at.
The O’Reilly video is worth a watch and makes it simple.
I’m intrigued to see if anyones had success in a T6?
Link here again
https://youtu.be/it_Grz7K1TQ
- intake manifold
- intercooler
- inner casings
- Turbo
Link here again
