Grumpywhelk
Hi all, My van has a leisure battery fed by the vans' normal charging system, with the switch to prevent overcharging etc. The problem is, in the winter with all the lights on and heater going, after a day, I need to start the van up and recharge the leisure battery as the EHU on sites merely gives me 240v power to standard 3 pin plugs fitted in the van...no charging. My plan...subject to what anyone advises is to :
Buy a bog standard trickle charger
Plug it into one of the 3 pin plugs at 240V from the EHU
On the dc side of the charger fit a male/female connector in line and this would link to + and - ring terminals on the leisure battery. i can then leave the battery end connector in situ. It sounds simple to me BUT....questions....
1. I will only charge with the van "off"...I am concerned that I will muck up the current charging system which works fine.
2. Will charging from another source (charging the leisure battery from 12v van battery whilst running and when not, charging as I've described above) muck any electrics up?
I hope that makes sense. Tim
