Eibach Pro 50mm springs sag when towing
James1982
Hi
I have the eibach pro 50mm springs from custom vanz and standard dampers. The van sits great but if I hook my bike trailer or put a bit of weight in the rear it sits lower than the front. Is this because the standard dampers are not sufficient , if so do I go for a B8 Bilstein?
James
Wouldn’t that always be the case though ? Put weight on whatever springs / dampers and they will compress ?
Yes, I think this problem has been posted before somewhere and it was the springs...
