Speedymaiden
Hi guys prepare yourselves for a long post but I appear to have an issue with my T6.
It’s got a battery draw on it that I know of which has caused the battery to go flat a few times after not being used for about a week. It recently had a brand new battery about 6 months ago which went flat the other day. As I’ve done before I jump started it as per usual with one to the positive terminal and one to earth in the engine bay as it has start/stop etc. The last time I did this it was fine however this time it was not. When I went to turn the ignition no lights come on so went to check the jump leads to find they were starting to melt so I quickly removed them. I removed the battery from the van and put on an overnight charge and re installed the following day, the van now starts everything is working etc but I now have some lighting issues.
Firstly I now have the light out symbol on the instrument panel
After checking all the lighting I’ve found the rear fog lights don’t work, when the light switch is pulled out no symbol appears on the dash and no rear fog lights illuminate
Secondly when the headlights are turned on the driver side dipped beam is on but passenger dipped does not work. When main beam is activated the passenger main beam comes on but driver side does not work
They are standard T6 headlight and rear light units
I’ve checked every fuse in the centre dash and multimetered them but have found no blown fuses
I ran VCDS last night and came up with the following codes ( see attached photos)
I’m now thinking it’s something relay related, if anyone has any ideas help would be really appreciated as it’s now not legally drivable with these dark mornings and evenings and once I get sorted I can get onto finding this battery drain the Van is a T6 150 highline manual if that helps
Cheers guys
Cheers guys
