electrical problem
stevey h
Hi everyone I've got an electrial problem on a t6 transporter . my hazzards light flash on my dashboard as do the indicators but none of the lights come on there is a bulb light on the dash also the break lights dont work . i have replaced sc47 turn and breaklights fuse but it still the same it didnt look blown anayway and the fuse port is live . and suggestions ?? please help
Do the tail lamps and reverse lamps illuminate?
There could be a multi plug disconnected in the loom to the rear lights? Has any work been carried out recently to the van?
yes i installed a reversing camera and piggy backed from the turn and break light fuse and the camera worked fine . would they all not work if a bulb had blown ? would a reset on the obd reader clear it ? Thanks for replying by the way . any help would be massively appreciated . obviously i have now removed the piggy back a put the proper fuse in but I now have this issue and going to garage is a bit of a problem with no indication . what would happen if you just removed the rear light cluster would I get the same issue or would some of the lights work like the indicators .Thanks for your help
