Hi all just starting my second conversion having learned so much from the first. One of my biggest regrets was having the Victron mains battery charger and the consumer unit fixed to the end of the units and slightly visible. Don't get me wrong it looked OK but I'd rather have stuff hidden and I simply couldn't squeeze those two components along with the leisure battery and ctek under the drivers seat. My thoughts this time round are to run the 240v mains feed and the dc dc charger feeds from the bonnet again and install the dc dc charger under the drivers seat on its own, then continue the 240v feed and dc charger outputs to the rear where the leisure battery, consumer unit and mains battery charger will be waiting along with the 12v fuse box then utilise the earthing point at the rear. Anyone on here done something similar? I'm using 10mm2 70amp wiring for the 12v feeds and 2.5mm Arctic flex for the mains. Things I'm concerned about are getting the right furniture to fit the rear components I want hidden away but accessible and voltage drops over that distance.
