Hi. What was the outcome of this? Think I have the same issue.Hi guys,
I have a fault engine light coming on. I read it and it comes up as a engine coolant bypass valve stuck and also engine coolant bypass valve control circuit high it is on a 204 t6.1 2023 model with 8000mlies
Having the same issue. Would be great to hear about the outcome. Can you drive with the fault until its fixed?Hi. What was the outcome of this? Think I have the same issue.
Guy also said as it had turn red then he would had advised not to use it, but as it was orange he said it would be ok Till the part arrived.Having the same issue. Would be great to hear about the outcome. Can you drive with the fault until its fixed?
Engine light came on in orange and when I plugged the OBD reader it said there was a problem with the engine coolant bypass valve control circuit, and that is what they said they had changed under warranty.What is the fault code?
It's also part of a "common fault bulletin" at VW but isn't a recall. 2022 T6.1I've had this fault today. MARSHALL told me they couldn't get it in for diagnostics until 27/3!
Vw assist came and diagnosed. They've ordered parts and fair play to the guy..... he's fixing it on the driveway tomorrow.
@mmi @Pauly - can we get a copy of this bulletin and post it in the downloads?It's also part of a "common fault bulletin" at VW but isn't a recall. 2022 T6.1
