conor.watkins1
Hi all, this is slightly different to the other threads on similar issue cutting out at lower gears/revs.
I've got a T6 T28 102 SWB on a 67 plate. The van keeps cutting out at low revs in particular 1st and 2nd and now started doing it in neutral and reverse. Engine cuts out with loss of power steering. Starts first time afterwards. No fault codes or lights on dash.
I have managed to narrow this down, it tends to happen after i have filled up with diesel. Tried turning off start stop, changed fuel filter. It feels as if it's not getting enough fuel at lower revs or some sort of air lock. In higher gears and speed there's no throttle response issues or acceleration issues, was thinking potentially fuel pump.
Any advice welcomed, only just overcome an egr issue which cost me a fair bit and at whits end with it.
Thanks,
Conor
Thanks,
Conor
