phantom-uk
Good day.
2016 T6 Euro6, 72,000 miles
New cam belt, auxiliary belt, water pump in 2021, serviced regularly.
Short runs every other day around city.
1. Engine coolant light on permanent Red now. Coolant disappearing somewhere during drive but once stopped and engine cools down the expansion vessel top is opened and the coolant refills itself from the engine to the correct level (some sort of vacuum sucking and holding it somewhere ¯\_(ツ)_/¯).
2. Sluggish to start most of the time.
3. In 2021 diagnostics showed glow plugs a problem so changed 3 out leaving the one with the sensor in place, no more fault codes since.
3. Today, a ticking/knocking from top of engine, belt and pulleys end maybe. Engine management light on flashing Orange, loss of power, difficult to start.
What’s the prognosis?
Hit me with it, I’m dreading the replies!
Thank you.
Thank you.
