I have had the alignment done twice in a few months, however the it still pulls slightly left and the steering wheel is still off centre.Initially I would get your alignment check and corrected, hunter would be the best way forward.
As above, how are the tyres wearing might help us give more guidance on this.
See below re photos of FNS tyre.Initially I would get your alignment check and corrected, hunter would be the best way forward.
No suspension alterations at all.Have you altered your suspension setup?
Can i please ask what Hunter is ?Initially I would get your alignment check and corrected, hunter would be the best way forward.
Can i ask what ‘hunter’ is please ?Initially I would get your alignment check and corrected, hunter would be the best way forward.
Mine too are 12months old. Mine is a 102 and doing it on both fronts - faulty batch maybe? I dont think its worth kicking off because they’ll just say not designed for commercial vehicles albeit the rating is correct.Hi Ian
Thanks for that re Hunter system and that sounds good if i can find somewhere nearby that uses it.
yes they are Bridgestone all weather control tyres, i just can’t understand why its only the FNS that’s falling to pieces.
There is some power being layed down with the 204 bhp but even with the odd unintentional wheel spin you would expect both tyres being worn especially with the front end weight of the van.
The tyres are 12 months old now and the set before this lasted 9 months which i was absolutely amazed at !!
Roundabouts and road camber....i just can’t understand why its only the FNS that’s falling to pieces....
Roundabouts and road camber![]()
I get that about the roundabouts etc but i left my quick driving days behind a good few years ago and plod around now, no other vehicle i have ever owned has ever worn tyres out this quick and like someone else said its almost worth putting a steal set on which aesthetically looks poor but hey ho !!Roundabouts and road camber![]()
“Looks poor” That’ll upset a few of the membersI get that about the roundabouts etc but i left my quick driving days behind a good few years ago and plod around now, no other vehicle i have ever owned has ever worn tyres out this quick and like someone else said its almost worth putting a steal set on which aesthetically looks poor but hey ho !!
Back are rolling absolutely fine with even wear, !!It's nothing to do with grit on the side of roads is it? Mainly with it gathering on the kerb side and then pulling off at slow speeds turning full lock cutting them up? Is back the same?
I live just outside of Crewe Cheshire so if anyone can recommend a place where Hunter is being used then that would be good.I’ve had 6 tyres scrubbed out in 2 years due to bad alignment, I’ve taken it to 5 different places and the only place that has managed to get the alignment correct is @BognorMotors and that was before they got a Hunter. If you tell us what area you are in somebody on here should be able to advise you on where to go and get the alignment done properly.
