Sold Exploria Kombi Bed
Phil Blackburn
@T6PBX
Putting my Exploria Kombi Bed up for sale, the Bed is size 4 so works with the Kombi seats fitted as you can see from the photos, black vinyl covers on the pads which are great as you can take them out and use them on the ground wipe them down and put them back in.
The frame legs have been painted.
Based in Manchester for collection only due to weight £675.00
Hi Phil
Are you and your good lady not going to any more camper Jam’s or Busfest’s ?
Hi, interested in your bed, what is the height from the floor to the bottom of the frame, new T6.1? I have a storage box on the LHS wheel arch and its fairly tall, i believe 63cms and i need the frame to go above that?
picture shows the side rail which is 600mm to the bottom cross rail which is 620mm and the base which is at 650mm, hope it helps
Yes mate comes with 4 legs that bolt into the standard tie down mounting points, you can see the rear ones in the picture and just make out the front ones which are the same. Really a solid mounted bit of kit you can use all the time.
