Fault code 00288
Steveg10
2017 VW Transporter T6 Dash Errors
Error: Stabilisation control (ESC)
Tyre Pressure Loss Indicator currently not available
Error: Start-Stop
Error message from Carista.
00288
Steering Column Lock Actuator (N360)
Any ideas how to fix this issue.
Error: Start-Stop
00288
Please post "Detailed ECU info"-report (under Carista Service menu)
ECU info obtained with Carista 6.5.2 for Android:
Code:
VIN: WV2ZZZ7HZHH112812
Engine
Part #: 04L906056KB
Component: R4 2.0l TDI
Software version: 6189
ASAM/ODX identifier: EV_ECM20TDI03004L906056KB
Coding: 0011401C430501090000 (hex)
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0133
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 347E4098256384802C7D0277A48421D3790000 (hex)
Fault codes:
00288 Steering Column Lock Actuator (N360)
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Software version: 1104
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 740F010300 (hex)
[No fault codes]
Airbags
Part #: 7E0959655H
Component: VW10Airbag01S
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003153 (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907040AA
Component: ClimatronicT5
Software version: 0510
ASAM/ODX identifier: EV_ClimatronicT5
Coding: 0000000103 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090B
Component: [none]
Software version: 0744
ASAM/ODX identifier: [none]
Coding: B8FC7DBA0AF33413922049642E2B9ED40D00698960446960320400BF0800 (hex)
Fault codes:
01838 Rader Interior Monitoring Control Module 2 (G305)
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042307 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Auxiliary heater
Part #: 7E0963273A
Component: STH-T5GP2
Software version: 0009
ASAM/ODX identifier: EV_AuxilParkiHeateWOST5G2
Coding: 4101 (hex)
[No fault codes]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B7A73 (hex)
[No fault codes]
Infotainment system
Part #: 5C0035680E
Component: MU-S-ND-ER
Software version: 0359
ASAM/ODX identifier: EV_MUStd4CTSAT
Coding: 06570001BE00000011111101008808001F0101C6002001004F (hex)
[No fault codes]
Reactions: mmi
Thanks @Steveg10
I have noticed Carista doesn't always associate codes correctly. The 00288 probably doesn't belong to ABS.
More likely the actual fault code is 0288 - Steering angle sensor
To determine more details we would need fault code extension, which Carista unfortunately can't provide.
Also the dash messages (ESC, TPMS fail) could be consequences of failure in steering angle sensor.
Any work done in the neighbourhood of steering wheel ?
Nowadays Carista can show some live data - by any chance anything about steering angle to verify the sensor is alive?
Thanks @Steveg10
Where can i get s new steering angle sensor from and is it hard to fit?
I've not had any work done on the steering. The errors just popped up when i was driving one day.
Is your steering wheel off centre or feel like the tracking is out
Reactions: mmi
