I'm hoping someone can help me understand how to debug this strange error, as per the subject line, that I've just found using OBDeleven on our T6.1 van.
The error is on the Gateway control unit.
I've tried clearing it several times but it is persistent so I guess the additional installation is still there and hasn't been correctly coded??
It seems to be the opposite to the missing devices discussed in this old thread but I dunno how to find what is causing the fault....
- How do I create the full scan report discussed in the older thread above?
- How do I identify what the installation is that has been detected?
- I have failed to work out how to find the full scan report or the list of devices discussed in that thread.
As noted in this thread, I replace our steering wheel in June. I never bothered checking OBD at the time because it just worked without any problems. This is the only modification I've done this year, other than the LED headlight bulbs late last year but I'm pretty sure I cleared the errors that the bulbs were causing.
- Could it be the different switches on the steering wheel that are being seen as additional installations?
Sorry to be so useless - I hope someone can point me in the right direction to clear this up.
Thanks!
David
Fault U112100 Databus missing message
I recently switched the factory Composition Colour Head Unit in my T6 for an Alpine Halo 9. I fitted it with the Alpine APFX300VW CAN to UART interface. The new head unit is working fine and I just got a ODBEleven device so I could enable the navigation control unit for directions on the MFD...
www.t6forum.com
[Guide] T6.1 MFSW Steering Wheel Upgrade
No actual connectors on the back, so no. Unless you soldered some to the board. Yeah, I finally managed to find some photos of buttons on eBay with the connectors, so I knew what I was looking for. Now my only problem is I don’t know which of the connectors is for the DSG paddles, since some of...
www.t6forum.com
Thanks!
David
