Evening all,
I've had the van for 5 months and mostly run it locally during weekends, whilst I decide on what day van conversion I want.
After using the van last night without issue I jumped in today and the Engine Management Light was on, no obvious problem or performance issue, I completed my journey and then hooked up ODB11 and got:
P20EE00 - SCR NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 1
P007B00 - Charge Air Cooler Temperature Sensor
Had a bit of a look on here for similar threads and then reset the codes and took the van for a good 20 mile blast down the dual carriageway. No re-occurrence of light or faults.
Ad-blue says 4000 miles 1Gal Min - 1 Gal Max (in fact has done since i've had the van)
Just a bit nervous as i'm in the last month of my warranty.
Full log from ODB11: Not sure what the date is about against the fault - Date: 2064-01-26 10:39:18????? Or why it refers to Adaptive Cruise Control when I only have standard cruise control?
Question is do I need to worry about these codes?
Log File:
Log File:
Code:
Date: 2023-07-29 21:01
VIN: WV1ZZZ7HZJH073498
Car: Volkswagen Transporter
Year: 2018
Body type: VAN
Engine: CXHA
Mileage: 165840 KM
01 Engine
System description: R4 2.0l TDI
Software number: 04L906056KL
Software version: 6166
Hardware number: 04L907445
Hardware version: H02
ODX name: EV_ECM20TDI03004L906056KL
ODX version: 004012
Long coding: 00194014432401090000
Trouble codes:
Intermittent
P056200 - System Voltage Low Voltage
Intermittent
P007B00 - Charge Air Cooler Temperature Sensor Circuit Range/Performance
Intermittent
Mileage: 165700 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Unknown ambient data: 17EB002242396332F6712096284490010644D200AC445400B9028D00B9445C00C844820334
03 Brakes
System description: ESC
Software number: 7E0907379P
Software version: 0133
Hardware number: 7E0907379M
Hardware version: H06
Serial number: 62807000000282
ODX name: EV_Brake1ESCCONTIVN75XGP2
ODX version: 011001
Long coding: 307E4098256984810C79027FA48A21D379F100
Trouble codes:
No trouble codes found
04 Steering Angle Sensor
Trouble codes:
08 Air Conditioning
System description: Climatic-T5
Software number: 7E0907047AJ
Software version: 0708
Hardware number: 7E0907047AJ
Hardware version: H22
ODX name: EV_ClimaticT5
ODX version: A01003
Long coding: 0000000003
Trouble codes:
09 Central Electrics
System description: BCM PQ25 Max4
Software number: 7E0937090C
Software version: 0752
Hardware number: 7E0937090C
Hardware version: H82
Serial number: 4000 283170180
Long coding: A0FC793A0A61341193284F606CEB8FF4C084738960CD79603304003F0860
Subsystems:
System description: RLS 270917 04
Software number: 5K7955559C
Software version: 0106
Hardware version: 47
Long coding: 0228EE
System description: J386__TSG_FT
Software number: 7E0959801R
Software version: 0653
Hardware version: 004
Serial number: KU0KU011101772842418
Long coding: 1400B1
System description: J387__TSG_BT
Software number: 7E0959802Q
Hardware version: 003
Serial number: KU0KU028091772710542
Long coding: 0400A1
System description: DWA-Sensor 00
Software number: 7E1951172
Software version: 0104
Hardware version: 001
Long coding: 000000
System description: LIN BACKUP HO
Software number: 1K0951605F
Software version: 0008
Hardware version: H01
Long coding: 000000
Long coding: 000000
System description: E221__MFL-DC1
Software number: 7E0959442
Software version: 0103
Serial number: 29170001808600127394
Long coding: B0FFFF
Trouble codes:
10 Parking Assistance
System description: PARKHILFE 8K
Software number: 7E0919475AA
Software version: 0212
Hardware number: 7N0919475
Serial number: 28231724901660
ODX name: EV_VW75XParkAssis8K
ODX version: 001012
Long coding: 30800C
Trouble codes:
13 Adaptive Cruise Control
System description: ACC Bosch PQx
Software number: 7N0907572C
Software version: 0211
Hardware number: 7E0907572
Hardware version: H03
Serial number: 2409170440AC70
ODX name: EV_ACCBEGVW361
ODX version: 001006
Long coding: 00004000FE0779
Trouble codes:
15 Airbag
System description: VW10Airbag021
Software number: 7E0959655G
Software version: 0018
Hardware number: 7E0959655G
Hardware version: H08
Serial number: 003V3006KMML
ODX name: EV_AirbaVW10BPAVW12X
ODX version: 001028
Long coding: 000000000000000000000000000000003231
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 7E0920970S
Software version: 1107
Hardware number: 7E0920970S
Serial number: 00000000000000
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A05733
Long coding: 740F010300
Trouble codes:
19 Gateway
System description: GW-K-CAN TP20
Software number: 7E0909901
Long coding: 042307
Trouble codes:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03710
Long coding: 000000
Trouble codes:
55 Headlight Regulation
System description: AFS-ECU
Software number: 6R0907357C
Software version: 0050
Hardware number: 6R0907357B
Hardware version: 005
Serial number: --------------
ODX name: EV_HeadlRegulVWLWRCC
ODX version: 002006
Long coding: 0FCE020001000000
Trouble codes:
5F Multimedia
System description: MU-S-ND-ER
Software number: 5C0035680G
Software version: 0468
Hardware number: 5C0035680G
Hardware version: H41
Serial number: VWZAZ2T5419495
ODX name: EV_MUStd4CTSAT
ODX version: 001022
Long coding: 065700013C00000011111101008808001F0100D6002001004F
Subsystems:
System description: ECE1 2023/24
Software version: 2010
Hardware version: ---
Serial number: --------------------
Trouble codes:
61 Battery Regulation
System description: Batt.regelung
Software number: 7E0907534
Long coding: 030B1A73
Subsystems:
System description: J367-BDMConti
Software number: 7E0915181K
Software version: 1050
Serial number: 758857000017092609CD
Trouble codes:
