Fault Codes
walkerbout
Walked off..
I have just had the epu checked and it came back with a few fault. I'm just wondering if anybody can shed some light on the faults and if I should ignore and delete them.
33262 - Reductant System Performance Bank 1
P204F 00 [096] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
25667 - Output for Starter Relay
P0616 00 [032] - Short to Ground
25672 - Control Circuit for Starter Relay 2
P3048 00 [032] - Short to Ground
30540 - Throttle Position Sensor (G69)
P0121 00 [032] - Implausible Signal
16230 - Control Module for Instrument Cluster
U1019 00 [032] - Missing Signal for Oil Level/Temperature
[Instrument cluster control moduleMissing signal oil
level/temperature]
27202 - Sensor Reference Voltage A
P0641 00 [032] - Open Circuit
27200 - Sensor Reference Voltage B
P0651 00 [032] - Open Circuit
27198 - Sensor Reference Voltage C
P0697 00 [032] - Open Circuit
27196 - Sensor Reference Voltage "D"
P06A3 00 [032] - Open Circuit
I'd like to see also full engine data section as there are many engine variants on T6.
You can ignore these as none is active. Also VW will ignore these as non-active. However, under warranty I wouldn't delete them - just in case they resurface. Often for warranty repairs multiple instances of a fault are required - not just a random.
Re the faults --> Vcds And Carista Fault Codes
As above,
I'd say most of them were caused by a flat battery at some point?
