Feed for switching Clayton LPS?
Jet
Just fitting a Clayton LPS II to my 6.1, for charging with the vehicle alternator they suggest the unit is switched via the D+ connection in the fuse board, I'm guessing thats a switched live, just wondering which fuse is safe to plunder. Sadly I'm not really clued up on modern vehicle electrics.
Yep go for a switched live, you'll need to go for the fuse box in the centre dash unless you are replacing a second battery in which case you could use the charging relay signal wire under the seat.
You don't have to plunder a fuse, have a good look in the fuse box and you'll note that the empty positions have the bus bar in one side and if you fit a fuse tap the correct way around you can take power without disturbing existing fuses.
See this thread for pictures of the fusebox:
And this for the fuse tap:
