Hi, I would be very grateful for feedback on my proposed refresh of the leisure battery system on my 2013 T5.1. Current set up is an 8 year old Travelvolts SCR with the addition of a 150w Solar panel on pop top. Van is currently used for weekends and weeks away using hookup. I am planning to spend more time in the Hebridean Islands & Orkney this year so need better off grid power.
I am planning initially to fit a Fogstar 105A Drift LB, a Victron Orion XS 50A DC-DC set at 30-35 Amps & a Victron 100/20 MPPT, under the passenger seat. My load calcs suggest this will give me 2-3 days off grid (fridge, lights & sockets), with no engine use. I looked at the 230ah Seatbase battery, but it stretches my budget and with my seat swivel I would need to remove the foam under the base and even then it would be tight. If a 105a Lithium Battery & 300w of Solar isnt enough I could fit another 105a battery under/behind the drivers seat.
My mains hook up is under the bonnet, I will also fit two RCBO breakers and my existing Victron 12/7 battery charger by the engine battery. I will also get an underslung diesel heater fitted (after I have the van undersealed). I'd like the design to allow the addition of a folding Solar Panel & small inverter run a Remoska later this year.
Any feedback on the (revised) Drawio diagram below would be brilliant.
Thanks Andy
Thanks Andy
