First Time VCDS User
Mister-E
I've read a fair bit about how to use VCDS and interpreting the results is going to take some time , so wondered if anyone could cast an eye over these?
I had no real reason to use the VCDS tool I purchased a few months ago until I randomly had the engine light appear on the dashboard yesterday afternoon.
On Sunday I drove about 30 miles on mostly A roads and everything was ok, no lights or anything to indicate an issue, but when I got home the fan noise from the engine bay was really loud, much louder than I'd heard previously. I thought it must just need to do its DPF cycle or something. I didn't give it any more thought.
Moving forward to yesterday (hadn't driven it since Sunday) I started the engine and the fan noise started immediately, which it has never done before and the engine light came on the dashboard. It stayed on, so loud I could feel it resonating in the cab. I drove around hoping it would go off, for at least an hour, including some 70mph dual carriageway driving. The noise only stopped when I turned the engine off, eventually. Same story this morning driving to work.
On my lunch break I decided to use VCDS for the first time and ran an auto test. Cleared the faults, then ran it again. The result is below. Anyone else had a similar result the first time and does anyone know what might be causing issue I described?
Code:
Wednesday,04,December,2024,15:19:47:57312
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.5
Data version: 20240715 DS356.3
[URL="http://www.ross-tech.com"]www.Ross-Tech.com[/URL]
VIN: WV1ZZZ7HZLH033431   License Plate:
Mileage: 24616km-15295mi   Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 5F 75
VIN: WV1ZZZ7HZLH033431   Mileage: 24616km-15295miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: Cannot be reached 0100
75-Telematics -- Status: OK 0000
Address 01: Engine (J623-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 SA    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9697
   Revision: 23301001
   Coding: 002540144364050900000000000000000000000000000000
   Shop #: WSC 00012 790 00060
   ASAM Dataset: EV_ECM20TDI03004L906056SA 004004
   ROD: EV_ECM20TDI03004L906056QF_004.rod
   VCID: 7EA227B5807A8BFA2DF-802A
   VINID: 9E606AAAA1D8A9C6000C310304E515D137
1 Fault Found:
15651 - Sensor for Ambient Air Temperature (G17)
          P0072 00 [00100011] - Signal too Low
          [Ambient Air Temperature Sensor CircuitLow]
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 24552 km
                    Date: 2024.12.04
                    Time: 15:15:36
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 16  C
                    Intake air temperature: 4  C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 10.968 V
                    Unlearning counter according OBD: 40
                    Turbocharger 1 turbine input: temp. sensor 1: B1: raw value: 75.0  C
                    Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 7.5  C
                    Particulate filter input: temp. sensor 1: bank 1: raw value: 7.2  C
                    Particulate filter output: temp. sensor 1: bank 1: raw value: 4.2  C
Readiness: N/A
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 046 N    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3107
   Revision: 00H06V09    CVN: 4644A9CA
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_VN46.rod
   VCID: 41D89C49B104340210D-8014
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 7LX-614-517-V1.clb
   Part No SW: 7LA 614 517 A    HW: 7LA 614 517
   Component: ESC_high      H01 0700
   Serial number: 08515417191208
   Coding: 30552452C84AEE880C5824A713677706392720B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3D20E0B9CDFC50E2745-8068
2 Faults Found:
0716 - Databus
          U1123 00 [00001001] - Received Error Message
          [Scl_KBI_Aussen_Temp_gef_Error]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:15:39
0717 - Databus
          U1122 00 [00001001] - Implausible Message
          [Scl_KBI_Aussen_Temp_gef_Invalid]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:15:39
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7LA 907 426 B    HW: 7LA 907 426 B
   Component: AC Manuell    H01 0502
   Coding: A03110000810000001000800504001050000000000000000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 42DA9345B4022F1A097-8016
   Rear air conditioning block 1:
2 Faults Found:
459025 - Databus
          U1121 00 [00001001] - Missing Message
          [Radio - kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:16:39
459527 - Databus
          [Klima_Sensor_02 - empfangener Fehlerwert]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Date: 2000.00.00
                    Time: 00:00:00
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01101935200762 Dataset Number: V03935315CB 0001
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205_VN46.rod
   VCID: 74B6059DBE36D1AA4BB-8020
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S3Y19M12D09H00M45S58
   Coding: 02B8EE
   Driver door control module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000036273068
   Coding: 1F000F
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000036031084
   Coding: 050007
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY193253SS3
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000032227710
1 Fault Found:
137218 - Outside temperature sensor
          B103F 1A [00001001] - Resistance Too Low
          [Geber f r Au entemperatur-> Widerstand zu klein]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:16:06
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0  C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058319344 Dataset Number: V03935304BK 0001
   Coding: 0451051811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_010_AU37.rod
   VCID: 50FEA90D6A6ECD8A8F3-8004
1 Fault Found:
13637888 - Databus
          [Steuerger t f r Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:15:38
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935303EM 0001
   Coding: 3200670201FF8748949C815580508700000000000000000004
   Shop #: WSC 00012 790 00078
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D49641AB182612021-8016
1 Fault Found:
1395 - Databus
          [FAULT_TEMP_FAIL]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:15:33
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 27  C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.22 m/s
                    Adaptive distance regulation: status: ACC_reversible_error
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    015 0506
   Revision: --------    Dataset Number: V03935308TZ 0001
   Coding: 8800C00000000000800000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X_VN46.rod
   VCID: 7F5CDAB1877082F2269-802A
1 Fault Found:
1054981 - Databus
          [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:15:33
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7LA 920 941     HW: 7LA 920 941
   Component: KOMBI         205 6750
   Coding: 27A4120A2480260001882A011401000000200000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VN46.rod
   VCID: 7DA020B98D7C90E2345-8028
1 Fault Found:
13639936 - Databus
          [Steuerger t f r BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:16:06
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 15121910521202 Dataset Number: V03935320AV 0001
   Coding: 030100044F05730001100018100F00010001070000000000000000000000
   GVL: 01443C0000000000400080008000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VN46.rod
   VCID: 70BE098DCA2EED8AAF3-8024
   Generator:
   Component: 4-01-09-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036344193870
   Coding: 2C1D00
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 773433010019120901B1
1 Fault Found:
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [00001001] - Performance
          [Globaler Timeout CAN-Infotainment]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 222
                    Mileage: 24616 km
                    Date: 2024.12.04
                    Time: 15:16:06
                    Terminal 30 power supply: 11.7 V
                    Terminal 15: OFF
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Dataset Number: V03935309JN 0001
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: EV_SteerAssisMNB_VN46.rod
   VCID: 45D08859A52C18222C5-8010
Address 5F: Information Electr.
Cannot be reached
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000909NVVR4 Dataset Number: V03935314UT 0001
   Coding: 06462000196818208005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VN46.rod
   VCID: 01585C49F184F40250D-8054
End----(Elapsed Time: 01:32, VBatt start/end: 11.4V/11.6V. VIgn 11.6V)-----
Sounds like it’s been trying to do a regen, but the runs haven’t been long enough for it to complete. If it’s mid regen & you turn off the engine, it’ll try to complete it the next time you start up. You need to get it upto 2300-2500rpm & hold it there for about 15-20 mins. Either on a main road or motorway.
‘15651 - Ambient Air sensor’ is located behind the front grille and is attached to the crash bar. Might not be related but isn’t the worst thing to get to - can be reached down the back of the grille if you’ve got the hands for it. Means taking the bumper off though to get proper access for inspection / replacement if not.
What outdoor temp does your MFD show?
Cleared the faults,
Could you please post the scan made before clearing the faults. In the scan above none of the faults is related to engine light.
1 Fault Found:
Looks like open circuit- broken wire perhaps?
I would start by fixing the sensor issue - could be even the culprit for the fan.
The DPF regen won't start immediately after cold engine start-up - it takes minutes. And to get the fan running takes even longer.
Hi, in this regard I would like to add that my T6.1 behaves differently to my previous T6. If I arrive at my destination and see the van is doing a regen and time doesn’t allow me to go for a drive then I sit and wait for the revs to drop, then leave the van to idle for a short while.Next time when I start the van it immediately behaves as it would doing a regen. Ie idles at the revs whilst doing the regen.
Thinking about it, pretty sure my van threw the engine light on when my ambient air temp sensor wiring was damaged. The MFD showed ‘- -‘ degrees C.
Here’s a thread that shows both the sensor and where it locates into its holder.
I saw this connector whilst I was putting something into my Shuttle. I fished it out as it is not connected to anything. There doesn't appear to be anything to connect it to. Anyone any ideas please? No fault lights on my dash. It doesn't reach the sensor.
View attachment 190057View attachment 190058View attachment 190059
Full disclosure. I changed the lights (front, rear and side) the other day and whilst I was extremely careful not to mess with the radar and temp sensor behind the front grille as I knew in advance that taking the front bumper off and moving the grille can cause problems with it. I guess I wasn't careful enough...but the lights are all working and look ace :cool: I had planned to try and resolve that at the weekend in the daylight. The MFD does indeed show ‘- -‘ and the parking sensors no longer work.
I was definitely more worried about the engine light and big list of supposed other faults, but if the temp sensor can cause the other things then not so much to worry about, but I guess I will see. I really wasn't expecting to see such a long list. @mmi The previous scan before I cleared the faults is below.
Reactions: mmi
The previous scan result part 1.
Code:
Wednesday,04,December,2024,12:56:06:57312
75-Telematics -- Status: Malfunction 0010
   Revision: 23301001
2 Faults Found:
          P0072 00 [10101111] - Signal too Low
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 24502 km
                    Date: 2024.12.03
                    Time: 14:01:22
                    Coolant temperature: 6  C
                    Intake air temperature: 22  C
                    Voltage terminal 30: 10.992 V
                    Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 0.7  C
                    Particulate filter input: temp. sensor 1: bank 1: raw value: 2.7  C
                    Particulate filter output: temp. sensor 1: bank 1: raw value: 2.7  C
27026 - Engine Oil Temp. Sensor (G8)
          P0197 00 [00100000] - Signal too Low
          [Engine Oil Temperature Sensor Circuitlow]
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 24259 km
                    Date: 2024.11.17
                    Time: 13:40:33
                    Coolant temperature: 9  C
                    Intake air temperature: 2  C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.429 V
                    Unlearning counter according OBD: 27
                    Fuel consumption: 0.00 l/h
                    Engine oil temperature: -50.1  C
                    Status of oil pressure switches-Oil pressure switch for high pressure: Open
                    Status of oil pressure switches-Oil pressure switch for low pressure: Open
                    Outside temperature sensor 1: B1: raw value: 9.0  C
                    Fuel temperature sensor 1: B1: raw value: 8.7  C
                    Control Module temperature: 8.5  C
                    Mean injection quantity: 0 mg/stroke
                    Accelerator pedal travel: raw value: 0.00 %
                    Limitation: torque: 175.8 Nm
Readiness: N/A
   Coding: 0014
2 Faults Found:
0716 - Databus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:26
0717 - Databus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:26
5 Faults Found:
459025 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 191
                    Mileage: 24016 km
                    Date: 2024.10.23
                    Time: 19:02:23
459527 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:22
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [00001001] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:49:47
                    Voltage terminal 30: 12.8 V
                    Compressor shut-off condition: Shut-off of engine control module via CAN (T > 15 sec.)
1048838 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Funktionseinschr nkung durch Energiemanagement Ruhestrom]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 15:27:09
                    Voltage terminal 30: 11.2 V
                    CAN input signal(s) status-Transport mode: On
                    CAN input signal(s) status-Static current measuring mode: OFF
                    CAN input signal(s) status-Windshield wiper: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Wipe wash: OFF
                    CAN input signal(s) status-Rear window heater actual value: OFF
                    CAN input signal(s) status-Back-up lamp: OFF
                    CAN input signal(s) status-Actual value of windshield heater: OFF
                    Blower reduction: No switch-off: no reduction
262658 - High Pressure Sensor
          B10AE 31 [00001000] - No Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:40:24
                    Outside temperature: 9.0  C
                    Compressor current: actual value: 0.01 A
                    Temperature downstream of evaporator: 10.0  C
                    System run time-Engine running time: 0 s
                    System run time-Terminal 15 on: 3 s
   Coding: 02B8EE
   Coding: 1F000F
   Coding: 050007
   Alarm horn:
9 Faults Found:
134667 - Voltage Supply for Terminal 30 of Exterior Mirror Heating
          B1900 13 [00001000] - Open Circuit
          [Versorgungsspannung Kl. 30 f r Au enspiegelheizung->Unterbrechung]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:35:00
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.0 V
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 13:54:50
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.3 V
206344 - Locking Unit for Central Locking; Driver Side
          B1679 29 [00001000] - Signal Implausible
          [Schlie einheit f r Zentralverriegelung Fahrerseite->unplausibles Signal]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 14:19:40
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.7 V
206604 - Locking Unit for Central Locking; Passenger Side
          B1680 29 [00001000] - Signal Implausible
          [Schlie einheit f r Zentralverriegelung Beifahrerseite->unplausibles Signal]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 231
                    Date: 2000.00.00
                    Time: 00:00:00
590853 - Window Regulator; Front Drivers Side
          B14D1 54 [00001000] - Missing Calibration / Basic Setting
          [Fensterheberelektronik Fahrer-> keine oder falsche Grundeinstell./Adaption]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 14:13:12
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.2 V
591108 - Window Regulator Motor; Front Driver Side
          U120D 00 [00001000] - No Communications
          [Motor f r Fensterheber vorn Fahrerseite-> keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 23
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 14:19:09
592133 - Window Regulator; Front Passenger Side
          B14D2 54 [00001000] - Missing Calibration / Basic Setting
          [Fensterheberelektronik Beifahrer-> keine oder falsche Grundeinstell./Adaption]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 247
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:36:47
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.9 V
592388 - Window Regulator Motor; Front Passenger Side
          U120F 00 [00001000] - No Communications
          [Motor f r Fensterheber vorn Beifahrerseite-> keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:36:51
598294 - Window Regulator Motor; Front Passenger Side
          U1210 00 [00001000] - Implausible Message
          [Motor f r Fensterheber vorn Beifahrerseite -> unplausible Botschaft]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:44:10
   Coding: 0451051811
1 Fault Found:
13637888 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:25
2 Faults Found:
1395 - Databus
          [FAULT_TEMP_FAIL]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 12
                    Reset counter: 222
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:23
                    Control Module temperature: 6  C
                    Longitudinal acceleration: 1.69 m/s
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VBAT_BUSMON_LOW]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 3
                    Mileage: 24016 km
                    Date: 2024.10.23
                    Time: 20:37:36
                    Voltage terminal 15: 9.8 V
                    Control Module temperature: 47  C
                    Longitudinal acceleration: 1.66 m/s
                    Adaptive distance regulation: status: ACC_StandBy
1 Fault Found:
1054981 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:23
5 Faults Found:
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:14:41
16777020 - Function Restricted due to Interrupted Communications
          [BAP_TEL_0x28 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:14:41
16776980 - Databus
          U1121 00 [00001000] - Missing Message
          [PLA_Status_01 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:40:21
13639936 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 13:54:50
9456681 - Key
          B104C 29 [00001000] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 24574 km
                    Date: 2024.12.03
                    Time: 16:22:23
   Generator:
   Coding: 2C1D00
4 Faults Found:
131594 - Parallel Parking Assistance Control Module
          U104E 00 [00001000] - No communication
          [Timeout Knoten 0x0A / 76 - Steuerger t f r Parklenkassistent]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:40:23
                    Terminal 30 power supply: 11.4 V
                    Terminal 15: On
131604 - No Communication with Instrument Cluster
          U0155 00 [00001000] - -
          [Timeout Knoten 0x14 / 17 - Steuerger t f r Schalttafeleinsatz]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 241
                    Mileage: 24150 km
                    Date: 2024.11.04
                    Time: 15:33:03
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: OFF
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 222
                    Mileage: 24016 km
                    Date: 2024.10.22
                    Time: 17:27:06
                    Terminal 30 power supply: 12.6 V
                    Terminal 15: OFF
8526361 - LV Energy Management
          B1802 F1 [00001000] - Warning Triggered
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.28
                    Time: 18:58:54
                    Terminal 30 power supply: 11.5 V
                    Terminal 15: On
   Coding: 0106
Cannot be reached
4 Faults Found:
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Multi Function Display (0x0F) - Funktionseinschr nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 23
                    Reset counter: 39
                    Mileage: 23947 km
                    Date: 2024.10.21
                    Time: 18:19:37
                    Voltage terminal 30: 12.0 V
9457171 - Audio signal output 1
          B14F1 13 [00001000] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 6
                    Reset counter: 9
                    Mileage: 24016 km
                    Date: 2024.10.22
                    Time: 17:19:35
                    Voltage terminal 30: 12.6 V
2566 - GPS Antenna
          B1054 13 [00001000] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 9
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 30: 11.8 V
9455892 - Mute switch radio
          B1049 14 [00001000] - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 9
                    Mileage: 24016 km
                    Date: 2024.10.23
                    Time: 19:31:07
                    Voltage terminal 30: 11.5 V
End----(Elapsed Time: 01:31, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
Wednesday,04,December,2024,13:07:21:57312
VIN: WV1ZZZ7HZLH033431   License Plate: AO20 XPT
Reactions: mmi
Previous scan result part 2
Code:
   Revision: 23301001
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 24502 km
                    Date: 2024.12.03
                    Time: 14:01:22
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 24259 km
                    Date: 2024.11.17
                    Time: 13:40:33
Readiness: N/A
   Coding: 0014
2 Faults Found:
0716 - Databus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:26
0717 - Databus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:26
5 Faults Found:
459025 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 191
                    Mileage: 24016 km
                    Date: 2024.10.23
                    Time: 19:02:23
459527 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:22
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:49:47
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 15:27:09
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:40:24
   Coding: 02B8EE
   Coding: 1F000F
   Coding: 050007
   Alarm horn:
9 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:35:00
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 13:54:50
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 5
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 14:19:40
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 231
                    Date: 2000.00.00
                    Time: 00:00:00
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 14:13:12
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 23
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 14:19:09
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 247
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:36:47
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:36:51
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:44:10
   Coding: 0451051811
1 Fault Found:
13637888 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:25
2 Faults Found:
1395 - Databus
          [FAULT_TEMP_FAIL]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 12
                    Reset counter: 222
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:23
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 7
                    Mileage: 24016 km
                    Date: 2024.10.23
                    Time: 20:37:36
1 Fault Found:
1054981 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 14:01:23
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:14:41
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.24
                    Time: 12:14:41
16776980 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:40:21
13639936 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 220
                    Mileage: 24566 km
                    Date: 2024.12.03
                    Time: 13:54:50
9456681 - Key
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 24574 km
                    Date: 2024.12.03
                    Time: 16:22:23
   Generator:
   Coding: 2C1D00
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 24322 km
                    Date: 2024.11.17
                    Time: 13:40:23
                    Terminal 15: On
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 241
                    Mileage: 24150 km
                    Date: 2024.11.04
                    Time: 15:33:03
                    Terminal 15: OFF
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 222
                    Mileage: 24016 km
                    Date: 2024.10.22
                    Time: 17:27:06
                    Terminal 15: OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 24016 km
                    Date: 2024.10.28
                    Time: 18:58:54
                    Terminal 15: On
   Coding: 0106
Cannot be reached
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 23
                    Reset counter: 39
                    Mileage: 23947 km
                    Date: 2024.10.21
                    Time: 18:19:37
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 6
                    Reset counter: 9
                    Mileage: 24016 km
                    Date: 2024.10.22
                    Time: 17:19:35
2566 - GPS Antenna
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 9
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 9
                    Mileage: 24016 km
                    Date: 2024.10.23
                    Time: 19:31:07
End----------(Elapsed Time: 01:25, VBatt start/end: 13.9V/13.9V)-----------
Reactions: mmi
Low battery can cause all sorts of weirdness, i would check that front temp sensor connection and parking sensor plug down by the foglight then get the battery charged and reset all the codes and see what comes back
Thanks. I did plug that plug back in, but I remembered suddenly last night that I didn't push the red tab back in...
Well I can confirm the temp sensor had popped out of its hole. Put it back in and refitted the bumper. I can't quite believe something like that is so easy to knock out of place. Torrential rain stopped play so will test it all later.
Reactions: CJW
It’s just not cricket, this weather.
Tested everything this morning and no lights on the dashboard, no awful noise from the engine bay, temp sensor and radar/parking sensors all working. Still can't believe something like that can throw so much out. Next I will run another VCDS scan and see what comes back.
Ran another scan this morning after clearing the previous faults. Much less RED this time. My question now, is what might cause the remaining faults? I have replaced the stock head unit for an Alpine, so wondered if that might cause some of these? Otherwise I have no idea, but everything works.
Code:
Friday,06,December,2024,08:58:47:57312
www.Ross-Tech.com
VIN: WV1ZZZ7HZLH033431   License Plate: 06-12-24.V2
Mileage: 24661km-15323mi   Repair Order:
VIN: WV1ZZZ7HZLH033431   Mileage: 24661km-15323miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
   Revision: 23301001
Readiness: N/A
   Coding: 0014
1 Fault Found:
459025 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 24661 km
                    Date: 2024.12.06
                    Time: 08:53:34
   Coding: 02B8EE
   Coding: 1F000F
   Coding: 050007
   Alarm horn:
   Coding: 0451051811
   Generator:
   Coding: 2C1D00
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 24661 km
                    Date: 2024.12.06
                    Time: 08:53:35
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
   Coding: 0106
Cannot be reached
End----(Elapsed Time: 01:20, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
I might this weekend, if the weather permits, have go at trying to turn on some options or at least see what's available to activate, or deactivate on my van in VCDS.
If there a VCDS guide anywhere to what finding possible options are available for a van's model and age?
8, 19 and 5F would suggest you’ve got an aftermarket head unit?
