From what I am lead to believe you'll need the brackets and fittings for the floor base, then from there the holes that are required are marked on the underside of the floor pan? but Colin @VWVC will be able to direct you the best.
@Garethwatford, if you are in the Beds & Luton region, then Colin at @VWVC is based in Witney Oxfordshire, easily accessible off the A34 and A40, so poss a 1.5 hour journey for you across Milton Keynes. He is certified by VW to install seating systems and will give you a certificate of installation for your insurance company should you need it. A number of people I know on here have had work done by him including @Fish, @andythom188, @ZipcodeUK.
