You at any shows or meets this year Craig?
You will mate might enter into show n shineAwesome
See you at Jam then,I assume you will have the forum stickers on display.. especially after all.our backing in the comp
View attachment 37005 View attachment 37006 View attachment 37007 Well today it was time to fit these H&R anti roll bars to see if it stiffened the ride
1st I attacked the rear, now I have the LED headlights which means I have the levelling sensor mount to the rear arb, make sure you get the correct kit ie xenon arb otherwise it won’t work
Some views and opinions on them in this thread, if this helps @Hinsley
H&R Anti Holl Bars (ARB) Front + Rear
Now you've had a bit of time with these, have you noticed a difference? If so, have you had anything else done (springs, B14's etc..)
Noticed quite a few people seem to fit arb’s ?????
I have run b14s on many vans and campers without thinking anything but it was smooth and tighter overall better...... what does fitting h&r arb’s really improve???
Sorry in advance if it’s a dumb question ...I understand it’s a van not a track car
This is without doubt the best suspension mod I have ever fitted to a van I have had them on awhile now but the difference is like night and day, it’s still only lowered on 30mm springs and I won’t be doing anymore suspension mods now as it’s perfect
Hope this helps
I also have a T28 camper and found the H&R ARBs made negligible difference, but apparently there are two holes they can put them in and it’s the inner ones that stiffen them up the most. I need to get under mine and have a look what setting THQ fitted mine on.I'll probably go for the thicker ARBs as well after having B14s fitted a month ago.
The Bilsteins have turned the bouncy crashy ride of standard VW suspension my T28 camper conversion into a plush car type ride quality, however going round an off camber curve, or worse still series of the same, brings back a reminder that you're in a van with a fairly high centre of gravity and you still feel that initial split second lurch towards the ditch, dialling that back by linking each wheel with an even thicker girder has to help, all these improvements are tiny increments though, very 50 Shades of Indium Grey.
Isn't it the rear one that affects handling most though?@andys No need to get under the van. Just turn steering full lock. ARB is just behind the drive shaft.
@Davenjo Factory rear ARB on my T32 was 28mm dia. H&R is 30mm. So in effect you only need 1mm additional clearance across the radius.
