Bond some 9mm ply to the double skin around the edge of the window, and then screw into this.
You do not need to do the sides...because of the curve the sides will be under pressure when fixed.
I don't do the sides as the recess is much thinner compared to top and bottom.
If you take a look it should make sense.
