Fitting T6 Heated seat in to T5
notchback
Hi,
Can't seem to find anything specific on the forums for fitting a T6 Heated captain seat in to a 2007 T5.
I've had the seat fitted for a while and now winter is coming would like to wire up the heated seat element.
From what I gather, it is tricky to do this via the dashboard switch / VCDS method. So does anyone know an aftermarket switch kit that will work on the genuine T6 Heated seats? I don't mind if the switch has to be mounted on the side of the seat.
Someone must have done this?
Thanks!
This thread has good info including the parts required to do oem retrofit:
Alternatively, is it an option to use a switch like the mk4 golf heated seats?
I did read that, but it's for a T5.1, and those wiring looms they refer to are different from the older T5
