Fitting the OEM Auxillary Heating Ductwork
Flyboy
Hi all,
I'm just getting the bits together for my T6.1 highline Kombi parking heater fit. I'm a little bit stuck finding the right part number to order for the B pillar trim cover with pre-cut holes. Can anyone help? I did order one which I thought was correct but it was the California fit which I have now found out is wider that the one for my Kombi....I need palladium grey and one without the alarm hole. Can you ever get one?
Dave
I have a kombi without the alarm button but with parking heater so it’s definitely an available part
Have a look here, you might find some more info
Hi Deaky,
Many thanks and yes I have been reading that thread with interest :)
My problem being is I would like to find that trim panel in the dark grey not the light grey which is in that part listing. I thought I had found it but the wider one arrived. Am Ileft with the only option of cutting the original? Would like to get the part number of the correct colour pre-cut one if I can :-)
Dave
Ah, there isn’t one in anthracite only moon rock grey. I covered mine in vinyl
The panel is not available in dark colour for the kombi, only for the the California. I painted mine but wouldn't advise it because it marks so easily so will get them covered like Deaky at some point
Thank you Deaky and Pewt,
That was the conclusion I was coming to. It looks like cutting the holes in the original is my next step :)
I think the lines are marked on the back. Just make sure you get the grille for a Kombi and not a ‘velle
I made that mistake originally and as they are non returnable parts it's still in the garage somewhere :whistle: :slow rofl:
