Hi all, Had a flashing glow plug light intermittent over the past few days, Then that and the engine light today.
Fault now found and fixed.
The code was -
PO18300 -
FUEL TEMP SENSOR A - CIRCUIT HIGH
I thought it was the sensor but on further investigation found a corroded / broken wire just before the plug to the sensor. Looked like another pipe clip had cut into it. Wire repaired fault gone back to normal running.
The code was -
PO18300 -
