Sorting out some electrics in my van and I'm considering adding one of the votronics trickle chargers between my Lithium Leisure Battery & the AGM starter.
My van is not a daily driver and the starter has gone flat a few times (it's not a Moll... just gaps between use I guess). There is nothing critical running off the Leisure battery d2d so my idea was to trickle charge the AGM from the Lithium to maintain the starter battery for longer. When i take the van out the Lithium will then recharge via the B2b & hay presto - I've got an extended lifetime on my starter.
The main concern I have is that the float voltage of the Li might be too different to the AGM so the lithium discharges constantly with no actual benefit. Apparently the Votronic needs a net different of 0.7V between the batteries to activate. Anyone know if this is a relevant concern or any other reason NOT to do this?
Im aware that a better long term solution is dual output solar - just dont want to do that quite yet.
