KezandPhil
Morning All
Hope everyone is well. I have an issue with the domestic water pump not working. When you switch that tap on to call for water you can see the leisure battery v drops but nothing , no water, no noise, nothing. The converter has suggested the next step would be to check the pipes are connected to the tank and pump, tank was easy to find but where is the pump normally ?
Also, completely unrelated I think but just in case. It’s been a while since the van was used and found what looks like a strange substance under the van when I moved it yesterday, image below / attached. Any ideas what it is ? Lilkely to be anything to do with the van ?
