Front end knock
dshelton999
Hi,
I had a small knock from the front so I changed the drop links which seemed to sort the problem for around 100 miles.
The knock then came back so I checked they were still tight etc. I have checked the top shock nuts and they are tight.
It will knock over small bumps and I can also get it to knock if I shift the steering from left to right (harshly) whilst doing around 10mph.
Thank you for your replies. I will change the roll bar bushes and see how it is. If its still there, I will change the strut mounts.
Does sound like ARB mounts. Often you can move them by hand and see the play in the bush. Fit power flex. Only about 20 quid a side. Life time guarantee. We have in stock if you fancy a set , there are 3 different sizes however , measure them
Hey pal,
I will have a set off you if you can post them out? I can PM you my details? Am I measuring every side and the centre hole? Thanks
