There’s nothing special about the bolt. Measure the thread diameter that will be the ‘M‘ number and the length, not including the head.
example (not what you need) : M8x15.
Edit; they are not 10mm bolts as you mentioned, the head is 10mm across the flats, 10mm spanner.
That makes it an M6 bolt, now just measure the length of the one remaining and try it in the other two threaded holes (normally all the same length).
