Hi I’m just fitting a Webasto st 2000 heater to a t6 . It fitted under the floor below the driver seat . What is the best route from the heater to the fuel tank and does the pump go at the heater end or tank end ?
Hi2 things incorrect there - the fuel line should be horizontal or sloping upwards from the pump to the heater to prevent any air being trapped ( yours can only go downwards to the heater if you have underslung the heater, not so though if you had mounted it internally) - with such fine bore fuel line you can affect the heat output due to insufficient fuel being able to get past a trapped air bubble and the fuel filter is the wrong way round ( you will never see if it is dirty/clogged that way round)! When the pump operates it compresses the fuel and any air dissolved in it can expand and collect on the output side as the compression eases. The installation manual does state things for a reason.
You would have done better by placing the pump closer to the heater so that you could have the outlet lower than the heater to obtain the horizontal /upward fuel line.
It may well work at present but you may have problems in the future. When people have problems with heaters that I sell 99% of the time it is because they have not adhered to the installation manual instructions! ( Too many resistance points in a multi-outlet setup, incorrect size fuel line, incorrect routing of fuel line etc.)
This was for the ST model, if you are fitting an STC ( they use a different pump):In the short distances that you are talking about it is immaterial as to the position of the pump as long as you have an upward slope from the pump to the heater or it is horizontal, never downwards. Pump can be up to 4ft from tank and 28ft from heater, total length no more than 33ft.
Follow the installation manual is the best advice.
Latest info - do not use return line as there is a non-return valve that prevents taking fuel from the tank, all it does is drain the fuel line back to the engine!No fuel feed that can be used unless you have a factory fit coolant heater already.
You can use the return, just take the return connector off and add a tee direct to the tank pump unit spigot. As far as we have been able to ascertain the return goes into the tank at least to the 1/4 tank level after that it may be dodgy.
Or read the manual:
