Furniture board
Kolar Kid
Hi,
Has anyone had any joy sourcing plywood furniture board to make your own furniture? I’ve sent out a few enquiries, but not had any response. Maybe because I’m not a trader or not buying bulk.
Looking in the NW ideally, so I could pick it up.
TIA
What do you mean? As in it’s finished, etc? Or just bare ply?
I know Clearcut Campervans sell it, but they’re in Devon, and it’s not cheap…
I’m going the custom route but when I priced furniture board up it was unbelievably expensive.
So I’m just going normal ply and probably spraying it.
Lusso Campers in Leeds sell it as well but their range isn’t great.
Thank you Josh. Yes, I am referring to finished ply. It is normally a white laminate on one side and wood effect or coloured laminate on the other side. I’ll check out Lusso Campers.
It is expensive as you say, but a couple of sheets at £200 each is cheaper than buying a pre-cut arrangement.
Did you consider structural form ply (assuming you like the black look)? The stuff used for concrete formwork, etc. so pretty readily available
