Fuses Blowing Non Stop
Matt bremner
Arrrggghhhhhh the fuse has blown for the rear tail lights and the interior lights, changed the fuse, blows straight away, any ideas people???
Have you fitted anything electrical or modified anything lately?
If I have problems, it's normally traced back to something i've changed or modified.
First bit of advice would be don’t keep putting fuses in they are blowing for a reason
Have you modified anything, if no then let the dealer fix it, if yes then undo whatever you have done and see if it rectifies the problem
If you want to troubleshoot it give us some more details and we may be able to make some suggestions
Hmmm I have fitted after market rear lights from van x but that was over 3 weeks ago, I’m tempted to put the original lights back on and see what happens, it’s still under warranty from vw
Certainly where i'd start.
How do you know the fuse hadn't been blown since you installed the lights?
Defo worth a try, could try unplugging them and see if it stops popping fuses, I’m thinking water ingress after recent weather ??
That’s a good bloody shout, I was away camping with the van the weekend, and we were in that storm, and then the next day the fuse blew, no problems before that with the after market lights at all, I will take both lights off now then and check for water and give them a good dry and see what happens, if not I will put the original back on and plead ignorance to vw lol
