Genuine VW interface loom or not?
bullracing
Apparently this is a genuine vw part. A genuine vw interface.... can anyone confirm please?
To me (unexperienced) it looks just like the connects 2 kit my local stereo shop had in stock. I decided to buy what I hope is genuine. Is it a genuine vw item and has anyone a picture of theirs?
Because they supplied a Kenwood unit from factory or as an option. Are we saying VW use a connects 2 to fit a Kenwood unit when you are buying a new van?
If thats the case then fair play, as i said, I'm inexperienced.
It’s probably a genuine Kenwood VW interface. Looks like the one that was fitted to my sportline years ago.
Brill thanks Deaky. Going in never to be seen again so want to know what I've installed.
I think I was expecting a vw/audi badge on it like all the dab and aerial connectors etc.
hmm. I am still not convinced with this.
If I order a new vw and specify this Kenwood unit, I would not expect there to be faults registering. I've tried everything and it continues to show fault codes. I also cannot get the nav to display on the screen. Apparently this would have if it was fitted by VW and the interface would work perfectly within the vans canbus.
so is this really a VW lead? Can anyone confirm this before I end up taking it to my local dealer to confirm?
The DNX518 that was OEM in my old sportline did not display the nav instructions on the MFD
How do you mean it's showing fault codes. It is not codeable and you'd have to untick module 5F from the installation list.
@Absolut5 will be able to give you the best advice
I'm pretty sure they are not factory fitted. As far as I am aware, they are dealer fitted at PDI.
If I code it out, it brings up an error, if I code to 56 I get an error, no matter what I do, I get the error that it cannot communicate.
Maybe I am pushing the wants/limits and possibly cannot get the navigation to work on the display but I would not expect the faults if the interface done what its supposed to?
Yes they may well be dealer fitted and not factory but they are option at the dealer. This is a VW dealer we are talking about. VW would not allow it (I would hope) to have errors.
Mines a 2016 so it is on the limits but it came from a T6. Although not a guru, I can work my way around vcds.
Look I do not want to be getting into arguements over it being an aftermarket stereo and not VW etc etc, I do not feel I am asking anything too awkward.
Its all here on the Kenwood site and at 2mins 55seconds it shows it on the display. Perhaps I am missing something that needs adding?
In the CAN gateway list of installed modules you need to un tick module 5F (infotainment system) and module 56 (Radio) because you don't have either of them installed. This is why you are getting errors.
Thanks Deaky
I have done that. I then get an error because it knows there is something there. From reading other threads it automatically sets 56 and so I get the error. I am unable to access it to code it further.
My van is in storage, not at home so I will get another when I pop down there next.
Cent. Elect. fault is because the rear motion sensor is disconnected, I've not figured out how to code it for just the front yet.
This was from one of the scans from today after trying different things.
Code:
Monday,23,November,2020,09:10:30:26804
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZGH04xxxxx   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 18 19 25 37 56 61 69 0B
VIN: WV2ZZZ7HZGH0xxxxx   Mileage: 27770km-17255miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KM    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6186
   Revision: 23002001
   Coding: 0019401C430401090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KM 004013
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 020B54C69567A5961D-8056
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 42505000001532
   Coding: 307E40982566847E0C7B027CA48221D3790000
   Shop #: WSC 02739 790 50316
   VCID: 3F8D9D32A615087E32-806A
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 26061504650890
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF32036E19FC17679-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 R    HW: 7E0 907 047 R
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 3979F32AB831264E0C-806C
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 246150901
   Coding: A0F4793A0A231493922849642E0B9C548D84698960440970320400BF0840
   Shop #: WSC 43013 002 104857
   VCID: 68DF666E9B1B6FC6A3-803C
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU027081552393158
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU007091552501498
   Coding: 0400A0
   Subsystem 3 - Part No: 7E1 951 171
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 5 - Part No: 7E1 951 171
   Coding: 000000
   Subsystem 6 - Part No SW: 7E0 959 442     HW: 7E0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170002737200037506
   Coding: B0FFFF
1 Fault Found:
50990 - Unknown Error Code
            Unknown - 014 -
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 27773 km
                    Time Indication: 0
                    Date: 2020.11.23
                    Time: 09:02:57
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 E    HW: 7E0 959 655 E
   Component: VW10Airbag00C 008 0016
   Revision: --------    Serial number: 003PJ000EW8F
   Coding: 000000000000000000000000000000003043
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 387FF62E833B3F46F3-806C
   Crash sensor for side airbag: driver side:
   Serial number: 3495ZRB40693FGI6E89U
   Crash sensor for side airbag: front passenger side:
   Serial number: 3505ZRB40573FGI67P5P
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Serial number: 00000000000000
   Coding: 710D010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3365C1029A5DDC1EC6-8066
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 273     HW: 7E0 963 273
   Component: STH-T5GP2     002 0007
   Coding: 4101
   Shop #: WSC 02759 790 50316
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 6ADB1C668D175DD6B5-803E
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042305
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 27773 km
                    Time Indication: 0
                    Date: 2020.11.23
                    Time: 09:06:01
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 1008
   Serial number:
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 52232F34531261520254
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000495347083
   Coding: 0100000100000000
   Shop #: WSC 12345 123 12345
   VCID: 306FCE0E634BE706BB-8064
End-------------------------(Elapsed Time: 03:05)--------------------------
Untick Radio 56 and navigation 37 in the can gateway installation list. The tick in navigation is probably defaulting the radio to be ticked too.
I unticked radio and nav. There was then an error and it automatically added the radio again with the fault. So there must be a problem my end but still amazed there is no way to clear it. The VW dealers must ignore the error on every van that has it fitted.
Nav stopped working when I untick navigation so ticked it and it came up on the dash but I then get the error nav not installed. Its not a problem as it still shows up but I am surprised that vw and kenwood thought the errors showing up was acceptable. That just boggles my mind that they did not care about it. All working but just get the faults showing.
