Glow plug flashing.
Ian.D
Hi, It's a 204 cxeb,61,000 miles, 2018. Recently it seemed strange that when turning the ignition on to start you could let go of the key and it would then start a couple of seconds later. I had a Nox sensor fitted around 3 months ago after the engine management light came on. The engine management light came back on about 4 weeks ago, then it disappeared, last week it returned, booked it back into the garage for this coming Friday. Then Friday evening it was around 1 degree outside, I went to start it and the glow plug started flashing, that also is intermittent, rang the garage and told them that there was something else to look at. I put the obd on and got the following codes that I have tried to find out what they are but to no avail.
p003eb8
p00797f
p0081ee
If anyone knows what these ones are it would be great, I had the charge cooler changed over a year ago, it's been Pendled around a year ago. I get the oil and filter changed every 6 months, serviced regularly....treat it like a member of the family, not that I'd want to scrub up and polish them every week. :eek:
Can you upload the full diagnostic scan?
It's an Icarsoft OBD2 , I'm not that adept with it in all honesty, just plug in and let it run , then check the fault codes, I haven't looked to see if there is a full diagnostic scan as yet. I ordered one of the Ross-tech vcds units first thing today , so Thursday hopefully will learn how to use it correctly.
Reactions: Loz
Things will be a lot clear once you have the VCDS scan
Hi Loz, firstly many thanks for your replies, I don't post often but I enjoy the site. So, this morning I had the time to connect the VCDS, It has shown the following, 16056-oil pressure switch P164B 00 (104) Malfunction-intermittent-confirmed- tested since memory clear
33262 - Reductant system performance bank 1 -P204F-00 (096). Malfunction-intermittent-not confirmed tested since memory clear
31103 SCR NOx Catalyst bank 1. P20EE (104) efficiency too low -intermittent- tested since memory clear
I thought I'd put the whole thing on there , I had the van into my local garage for an interim service last Friday, they did kind of treat me with a little indifference by saying that with the codes I should just go to Volkswagen to sort it....Or maybe I should find someone who actually cares ? Maybe that's just me being grumpy...lol. The glow plug light which was intermittent has been off for the last 5 days of driving, the engine management light is still on. Not sure if mentioning that makes any difference. Is it too simple to say just replace the oil pressure switch ? Plus as the NOx sensor was renewed not that long ago is there a plausible reason that's showing up ? Having delved around the forum I came across a post regarding the NOx and it seemed to end up being about the Ad blue level and not the sensor itself.
Lastly should I now be delving deeper into the vcds and finding out anything else ?
3 Faults Found:
16056 - Oil Pressure Switch
P164B 00 [104] - Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 101466 km
Date: 2056.01.06
Time: 00:14:23
Engine RPM: 1588.25 /min
Normed load value: 64.7 %
Vehicle speed: 31 km/h
Coolant temperature: 26 °C
Intake air temperature: 3 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.664 V
Unlearning counter according OBD: 39
Air mass at air mass meter 1: 230.4 kg/h
Standardized air flow ratio: 1.008 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 21.71 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 2.145 bar
Absolute intake pressure: 217 kPa abs
Mean injection quantity: 42 mg/stroke
Index of current engine mode: 0
Index of next requested engine mode: 0
Index of engine target mode: 0
33262 - Reductant System Performance Bank 1
P204F 00 [096] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [104] - Efficiency too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 97039 km
Date: 2054.01.18
Time: 07:48:44
Engine RPM: 1634.25 /min
Normed load value: 71.8 %
Vehicle speed: 90 km/h
Coolant temperature: 90 °C
Intake air temperature: 1 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.734 V
Unlearning counter according OBD: 40
Air mass at air mass meter 1: 223.2 kg/h
Outside temperature sensor 1: B1: raw value: 0.0 °C
Mass airflow sensor 1 bank 1 airflow: raw value: 1166.0 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 70.35 %
NOx sensor before SCR cat conv: offset correction factor: 0 ppm
NOx sensor after SCR cat conv: offset correction factor: 231 ppm
Reducing agent quality sensor: urea concentration: 0.00 %
Reducing agent quality sensor: raw temperature value: 0.0 °C
Does the glow plug light switch on with ignition and then go off within a few seconds? If so I think that is normal and will depend on the temperature. The light will switch on to show that the plugs are heating and then switch off. During the colder times of the year it will delay ignition whilst it takes slightly longer to warm (still only a few seconds) please ignore if I missed the point and you knew this already.
Dan
Hi, well I knew parts of it, the first time the light came on it was late at night and very cold, but it remained the next day. I had noticed this winter what seemed odd to me the slight delay on the ignition having turned the key and let it go the delay in starting up , my other T6 doesn't do it nor my XC40 , but every vehicle I suppose is slightly different.
I'm glad about your reply thank you, It's always good to have information put in front of you rather than spending hours hunting around.
It might be worth saying that the glow plug light then came on and off at different times when running and the temperature was around 5 degrees.
No problem Ian, my T6 102 is the same, the winter cold days have delayed ignition by a few seconds. During the warmer days you won’t even notice, Diesel engines can actually start without glow plugs under the heat caused by compression alone.
It would be best if you posted the full unedited VCDS scan (you can remove the last few digits of your vin if you want)
Hi, please excuse my ignorance on how to find everything within the vcds, it's my first time using it, feel like a kid again finding out new things every hour.
I hope this is what you meant @Pauly
Code:
VIN: WV1ZZZ7HZJ License Plate:
Mileage: 102110km-63448mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 19 25 55 5F 61 0B
VIN: WV1ZZZ7HZJH.  Mileage: 102110km-63448miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KQ HW: 04L 907 445 A
Component: R4 2.0l BTD H03 3775
Revision: 23101001
Coding: 00254014436401080000
Shop #: WSC 02762 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056KQ 004004
ROD: EV_ECM20BTD03004L906056KN_004.rod
VCID: 0655850ED8A6496A35F-8052
VINID: 9E606AAAA1D8A9A6011450411893F450C7
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 101466 km
Date: 2056.01.06
Time: 00:14:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 97039 km
Date: 2054.01.18
Time: 07:48:44
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5302
Revision: 00H11V01 CVN: DE654C7D
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 3D272AE2CDF0CAB2245-8068
No fault code found.
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H06 0133
Revision: 00000000 Serial number: 60778000002131
Coding: 557E409865678483AA760277A68821E679F700
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 40D95316BA02A75A4F3-8014
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 05031813470345
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5EDEE807611AA7DF-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 73B3CCDABB344CC2021-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 083180691
Coding: A0AC393A0A61341193284F606CEB8F74C084738960CD79603304003F0860
Shop #: WSC 02762 534 1614684
VCID: 2B0314BA230454028A1-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 220318 04 47 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 R HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 005 0653
Serial number: KU0KU020031880791897
Coding: 1400B1
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 004 0653
Serial number: KU0KU009031880681849
Coding: 0400A1
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29180000505120018102
Coding: B4FFFF
1 Fault Found:
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 58
Reset counter: 78
Mileage: 92386 km
Time Indication: 0
Date: 2022.12.08
Time: 06:47:32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261806902031
Coding: 30810C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFC6D2C1287ED2F0D-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 1903180453AF8E Dataset Number: 7E0114v____ 0009
Coding: 00005000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 363535CEE8C619EAE5F-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 J HW: 7E0 959 655 J
Component: VW10Airbag021 010 0018
Revision: -------- Serial number: 003EK000SENG Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
Shop #: WSC 02164 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 440F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3A2D21FEDCDEFD8A017-806E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042307
VCID: 6889ABB6F272BF1AA73-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DD1BEECFE8D0AB17-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: -------------- Dataset Number: V03600097E0 0001
Coding: 0FCE020001000000
Shop #: WSC 02748 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
1 Fault Found:
5275648 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 102
Mileage: 93871 km
Date: 2022.12.19
Time: 11:28:16
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0468
Serial number: VWZAZ2U0680037 Dataset Number: V03935266VJ 0001
Coding: 065700013C00000011111101008808001F0100D6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2517E282456062725C5-8070
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 DF HW: -----------
Component: ECE AS 23/24 --- 2010
Serial number: --------------------
1 Fault Found:
6720 - Rear View Camera
B1102 31 [008] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 76
Mileage: 102066 km
Date: 2023.03.18
Time: 09:53:51
Voltage terminal 30: 12.2 V
Sent from Mail for Windows
ok, so theres a few things highlighted there some of which will be erroneous errors and some maybe not
As is often the case with VCDS scans the dates are all over the place so using the mileage as a reference some of the faults are recent and a few seem historical (under 100k kms)
If it was me i would clear all faults using VCDS this will get rid of the old and/or irrelevant stuff, then do another scan and see what faults immediately come back, then after the vans been driven a bit check again and see if anything else comes back, some faults wont develop until the engine has been running (like the SCR/adblu system etc)
Looks like you have LED headlights in travel mode, go into the settings on the instrument cluster and untick travel mode (unless you are currently abroad ?) after you have done this and reset the errors i believe all the errors other than module 1 will clear
Once you know what errors are persistent then you can target you attention to those
It's usually a good idea to use non-aggressive scan mode.
This mode doesn't report ancient faults/glitches - also the results would be consistent with VW diagnostics. E.g. I would expect P204F to "disappear".
Thanks Pauly, I did notice the LED headlights had been left set to the wrong side after a trip abroad recently, I changed that this afternoon , I will do what you and MMI suggest and see what happens, it's great of you all to help.
