Glow plug removal without moving fuel rail
jesteh
Is it possible to replace cylinder 2 glow plug without removing fuel rail?
Longer version - got fault P0672 - cylinder 2 glow plugs faulty at 40k miles. Easy cheap option is to remove faulty glow plug and leave others as its occurred at low mileage. If that resolves the issue, its cost me very little. If the fault persists, I would take it to the garage who quoted me for replacing all 4 - I don't have the skills to remove the fuel rail.
I can't tell from the few online videos is whether just cylinder 2 glow plug can be remove while keeping fuel rail in place - it implies its possible for cylinders 1-3 but not entirely clear.
I changed the standard 3 glow plugs without removing the fuel rail. Only one was throwing a fault but did the other two at the same time. Didn’t change the one with sensor purely due to the cost but it can be done without removing the fuel rail. My biggest concern was that they would be seized in but luckily none of them were.
Many thanks, so I assume that means I don't need to re-pressurize or prime anything or use Carista or similar- just a socket/screwdrdiver set and I can do the job?
So I managed to remove glow plugs 1, 2 and 4 without touching the fuel rail.. The connector came off quite easily and I had no issue removing the glow plug
Glow plug 3 - I can't seem to get the connector off. Unlike others, this has a hard plastic connector and it just won't come off. Is there some sort of switch on the connector I need to flip first?
I need a set of glow plugs now due to no 3 pressure sensor code. On back order a lot of places. Anyone have any recommendations online to buy. If so are they any good?
Have you tried? I had the same fault recently so need the sensor one. Only changed them all 2 years ago !!!
No.3 was the one with pressure sensor - I got this from Halfords - Beru Glow plug 173251
Others 3 were also in Halfords - Bosch Glow Plug 438440017
Halfords price was decent for all 4.
