Could you extract "Detailed ECU info" from the Carista - curious to see if the fault codes shown in there are either organized under different modules, or even are different ones.I managed to purchase the Carista subscription earlier but can't find a resource for checking what the codes relate to, any suggestions?
View attachment 41655 View attachment 41656
Wow... that's a random set of codes....
2256 is something electrical plugged in when the van is sleeping.
Not sure about the others as they are so random as a collection...have you had a low or flat battery at any point?
You could just clear all the codes and see what comes back . . . . . If any.
Hi, I had a similar scenario, towing twin axle family dogs etc, glow light flashing, no loss of power no EML light, Oil temp up to 122 degrees, got home been fine for the last few days.I've had this error today, we were heading south on the A1 towing a caravan and doing 60'ish uphill on cruise control. I accelerated to overtake a wagon and nothing happened! I dropped to Drive, into manual mode, geared down and it still wouldn't budge so I floored it but the engine revs topped out at 3k.
The speed kept dropping until we were doing about 40 on the flat in limp mode so I pulled into services and parked up. My Carista wouldn't work, as the 30-day trial had expired and it wouldn't connect to iTunes so I could purchase it I gave up eventually and headed off home to find all was fine again, no flashing glow plug light and no limp mode so fingers crossed it was just a glitch.
By the way, the oil temp hit 115 about 20 minutes before, could this have been anything to do with it?
View attachment 41569 View attachment 41570
