How to remove the double passenger seat cover
Starting at one end of the lower part of the seat back, twist the back of the seat cover bar out of the channel.
The plastic bar is glued into the foam slightly, you just pull it away. Then gently turn the cover inside-out around the end brackets.
Unhook the cover straps by lifting the plyboard gently, and then gently peel the centre of the cover inside-out away from the main bracket.
For seats with a plyboard present, peel the cover all the way up to the top to remove the plyboard from the seat back. Either drill out the rivets or prise the board gently from under the rivets in the direction of the slot. You will need to remove the rivets and use new rivets to re-attach the board. Alternatively, you can remove the board and leave the seat without a flat back.
If you are just removing the bracket, you can muddle on with the plyboard in place, and can get away with only releasing the centre rivet.
Push a socket with a spline bit (T5.1/T6) or hex bit (T5) into the back of the foam to undo the three bolts that go through the bracket. Wiggle out the bracket (this sometimes take some force)..
Reverse these steps to fit a new bracket (pictures taken in reverse when I fitted my Vancraft, and there's no plyboard on mine!)
