Ever wish you never started something? Well, this is a candidate for it.
I didn't take as many pictures as I used to, as I'm familiar with tearing down seats now, but this had some new challenges.
Removing the covers should be easy but they are simply not made to be removed, compared to all the other seats in the panel vans, kombi and shuttles/caravelles.
Here's a quick version that I'll refine as I remember and re-fit the new cover.
1. Move the seat forward so you can get to the nearside side. Fold the seat down flat (bed mode) although I didn't!
2. Unscrew the retaining strap on the nearside of the seat base which allows the seat base pad to lift up.
3. In this position you should be able to undo the two panel clips on the top of the trim on the leading edge of the base above the front of the drawer (I didn't! And I'm still not sure how you are meant to).
4. With this trim out of the way you can pivot the seat base pad upwards (I couldn't!) and unclip the plastic hooks all around the cover. Some have pig rings keeping them on which need levering off with screwdriver or similar. There are velcro bits too.
5. If you're lucky (and I've not forgotten anything that I did) the seat base foam and cover will come off the base metal lattice work in one piece.
6. You just need to remove the 36 pig rings to separate the cover from the foam now (!). Don't pat yourself on the back, that was the easy bit.
