[GUIDE] How to remove bumper lower grill on a T6 (Trendline/Highline only)
Andysmee
Previously the last of the TSI's
Moderator
T6 Legend
Quick mini-guide on the lower grill removal. Just need a pry bar or soft screwdriver so as not to damage the painted bumper which is soft plastic.
Starting with the outer grill pieces, pry out the top inner corner.
Work across and down levering out the grill which pops the tabs.
Do the same underneath, it's not easy just take your time.
Finally, pull the end tabs free. Repeat with the other outer grill. Then do similar with the middle grill working towards the middle.
To re-fit, reverse the instructions, pushing each tab in firmly until it clicks.
If you want to remove the trim rails in the grill, they can be pushed out from behind just with your fingers. For example, to add chrome trim to them:
They just push back in by hand.
