Another mini-guide. I had removed the passenger seat first, which helps with access but isn't necessary.
Disconnect the seat belt latch sensor (I assume that's what it is) and slide the wire clip off the underside of the seat (top right).
Now, if you want to remove the seat from the base, undo the four bolts on top of the rails (slide the seat forward and back to access them) and the seat lifts away.
To remove the seat and base, wiggle off the same seat belt buckle wire's clip from the bottom of the rail.
Now you need to detach the handbrake from the seat.
How to remove the handbrake lever and covers from a T6
Lever the clip under the lever with a flathead tool. Pull the handle cover forward sharply to slide it off.
Lift the lower handbrake cover up off the pins on the driver's seat and slide it out over the handbrake lever.
Lower the handbrake to release the pressure on the mounting (make sure you are in gear) and undo the two 14mm nuts to remove the handbrake.
Undo the four 16mm nuts holding the seat to the floor and the driver's seat can now be lifted out of the van with the base
