Since getting my new van and having the @BognorMotors gloss front end i couldnt help but feel the wing badges looked a little out of place
These were the only bit of matt plastic around the front of the van so thought they needed to get gone so got myself a set of gloss black/chrome bulli badges
Now i like a little 'how to' thread so heres a quick run through
To remove the side repeaters you have to slide/press the light unit forwards towards the front of the van which allows the rear plastic 'hook' to unclip from the wing and the unit will come out
The electrical connector is locked in by the little grey tab on the plug
Sliding it out will allow the plug to be removed
Now you can remove the old badges, they break very easily so if you want to retain them then you need to go all around and free up the edges before trying to pull it off and pay extra attention to the thin plastic area around the indicator, this needs to be freed up before trying to remove the badge or you will end up with this
the adhesive pad will be left behind and this needs to be picked/pulled/rubbed away until you get some shiny paint on show
the badges have two locating pins on the rear so are very easy to fit
just line the pins up with the holes and on they go
i do like how the chrome in the LED headlight flows through into the badge
and the other side
and the other side
