Daviesmd
ok so I didn’t find much help online with fitting this into my VW and thought I would share - the guy who had it before me had a rear facing camera drilled through the badge which was letting in water- so after a lot of research I decided on the Auto Vox X2 because:
I spliced the rear sensor also into the rear light (green and black wire) which was also situated in the cable bundle that runs down the length of the van.
It is simple enough to remove the side passenger trims using a trim tool (these things are awesome) and wired the front dash cam into the Live with Ignition 1.5a. (The rear cam feeds directly into the forward dash cam).
Final thoughts:
- Has a rear camera
- Looks like a mirror
- Continuously provides rear view while driving
- Records both feeds at the same time
Final thoughts:
- Easy to install except for wiring through tailgate
- Great resolution on front, not as clear on reverse
- Great feature for the price
