H7 headlight qdjustment
PaulG9LXY
Hi all,
I bought a pair of H7 headlights off eBay to upgrade the candles in the standard H4 headlights.
Fitted now and adjusted the dipped beam fine, but the main beams are way too high (they light up house rooves brilliantly!) and I can't find any adjustments to lower just the main beams reflector aim.
Anybody have any ideas?
Thanks in advance!
Paul
Three things I’d check:
  • Are the bulbs seated properly?
  • Is your dash levelling dial set at the top by accident?
  • There are 2 plastic adjustment screws on each headlight. One adjusts horizontal, the other vertical. Can’t remember which is which.
Are they incandescent bulbs? I.e. standard H7s.
Others may have more thoughts.
Dipped and main beam H7s are seated correctly (both sides main beam is aiming too high)
Dash leveling dial is set to 0. I tried to set this to 3 to aim them down then angle the adjusters up, but the up/down 6mm hex screw moves both the dipped and main beams together.
The bulbs are Osram +200% halogen H7s.
I did find this adjuster in the main beam compartment, but it only moves the main beam left or right, and can't see another to move it up or down independently of the dipped beam.
Reactions: CJW
Yeah the 2x 6mm hex adjusters on the top of the light casing are the other ones I used to get the dipped beam angle correct. A friend has an MOT testing garage and we aligned them on the beam setter using those 2 top adjusters.
Main beam was still way too high.
I'll get a photo next time I'm out in it.
Reactions: CJW
